12-29-2019, 02:46 PM
I have a question about using MRCC live.
If you hold a chord on a keyboard (note on) and switch off the output that received the chord (note on), then what happens:
A. The chord will hang forever.
B. The chord is stopped when the port is switch off using "All Note Off"
C. The chord is stopped when the port is switch off by sending "Note off" on the keys used.
D. The chord stays until you lift your fingers from the keyboard (note off).
I hope that it does "D" and if it does will it work with both "Note Off" and "Note On velocity = 0"?
The same goes for other type of MIDI message, if something is send while a port is on the MRCC should track it and allow
"reset" message to get thru after the port is switch off.
Thanks For some nice devices that I hope to add to my collection soon.
Kent
Kent
