Explain LED lights animations
Can you please explain LED lights animations to me?
Where can I see the effect?
If I try to set them as activity / note monitor, I don't see any change.
Oh, found it in the cheat sheet
"Use SHIFT + Y (REMOTE) to toggle the LED light show on and off."
With the PORT MONITOR, can you explain why:
- the monitor is active only on outputs but not on inputs (speaking about DINs, strangely on USB it's active on inputs as well)
- the monitor is velocity sensitive, so unless I am hitting keys hard / sending high velocity MIDI notes, nothing might show up on outputs either
I would suggest to change this behavior to:
- show activity on inputs as well
- adjust the velocity sensitivity so that it lights up on lower velocities as well or scrap the velocity sensitivity altogether
The issue is affected by the LED brightness setting as well.
With max brightness is probably closest to desired implementation, but with min brightness, it needs even more velocity and actually changes to a different channel color with low velocity.
