Hi - the MRCC is fantastic!
Can you please extend the Assign Labels function to include the Remote7 I/O ?
Thanks, Mick
Having played around with label assignment, I've realised that the assignments are User patch specific, i.e. if you load User 1, then make I/O label assignments, they will all revert to 'none' if you load a different patch, e.g. User 2. If you re-load User 1, the assignments are back as they were.
Surely the label assignment is a global function, and would be better if not tied to User patches? I can see the reasoning behind making them User patch specific, i.e. you might need a completely different set of label assignments if you re-arrange your MIDI gear, so you just save User 1 as User 2 and re-assign the labels in a different arrangement from User 1.
OK - but what if you want to keep your current MIDI gear as is, keep the label assignments, but set up a different set of I/O routing patches and save them as an alternative User patch?
The only way to do this would be to load User patch 1 (having made new label assignments), then cancel all the I/O routing, then set up different routing. Then you would save that to User patch 2.
Both patches would share the same label assignments, but with differing I/O routing.
But...how can you easily clear all I/O routing? I've looked in the manual but I can't find any mention of how to clear all I/O routing patches (...or am I missing something?).
I think we need another Shift+button function for clearing routing (please).
Thanks, Mick
