08-20-2021, 09:53 AM
Hi all,
I've just discovered a minor bug where if you assign a Transpose Mod to a route and then save everything, the transpose amount (semitones) isn't saved.
The mod, the Transpose slot #, and the source channel are all saved, just not the amount.
Running firmware v1.1.030
Replicated by saving (tried both User 1 and User 2 presets), loading over it with the factory preset, and reloading the original
Replicated by doing a factory reset and repeating the above (only with User 1)
I also confirmed it isn't just transpose slot #1: added a second one with a different source channel, assigned to a different route, and it had the same behaviour. I haven't tested slots 3-6.
Thanks! Let me know if you need more info from me.
