Channel Modifier
Has anybody successfully used the Channel Modifier ?
I route DIN IN 1 to USB PC Virt 1. And I added a Ch3 modifier (in the ROUTING screen). But, the messages I send from my device arrive in the PC with the original port. I would like to force the channel when they arrive in the PC port.
Any help greatly appreciated.
Thanks.
Ok, I found how to it.
In the routing screen, you assign modifiers SLOTS and not the new value itself. I don't know how, but I managed to access the modifier configuration and there I can map the channels.
I have read the user manual at least twice but this was still not clear. Fiddling with the menus and the buttons (clicking everywhere) is finally the best way (for me) to learn how to tame this beast.
I know Steve added a function to quick jump to the Modifier Page of the slot you have selected with an encoder press, not sure if that's had a chance to make it into the manual yet, I will make a note to check, (and make that happen if not). Pressing the encoder again should take you back to the Routing page as well, I believe.
Thanks a lot for the info Jesse.
