Vst Software
Hi all,
I tried to look for posts about it but I didn't find anything. Is it possible to use 4 software instruments with the ndlr? How should I set up the instrument? Once all the USB ports have been assigned, nothing is heard. Advice?  what am I doing wrong?
Thankss
Hi David,
It is totally possible to connect 4 VST software devices to the NDLR. Can you tell me a little bit about your DAW and the instruments you are trying to connect, so I can try to give you the most accurate instructions please?
