07-28-2021, 03:41 PM
(This post was last modified: 07-28-2021, 04:07 PM by stefftastiq.)
Hi
Im facing some strange issues with the MRCC when connecting the NDLR.
I have a Sqarp Pyramid sequencing some synths (through usb 1) + running the clock, which syncs my computer (Ableton) + all my synths.
This works great (so far).
As soon as i connect the NDLR to one of the MRCC usb ports the clock jumps all over the place (on all devices)
Even when the NDLR has not been routed to anything.
If i put a filter on clock on the output port of the usb port NDLR is connected to it resolved the "jumping clock", but then the NDLR isnt getting sync
Been messing around with this for a while now and need some pro tips of how to fix this.
Found a post with disabling the clock out completely through the boot menu on the NDLR, but that did not help anything at all. (disabled 2 first options and the last option set to 1 instead of 1-4)
Was on the "current" beta, but also updated the ndlr to beta fw trying to figure this out + resetting to factory settings etc.
Can the NDLR be run as "slave" with only using USB?
Also how can this mess up clock on everything even when the USB port its connected to on MRCC isnt routing out to anything?
I see the NDLR sending CC19 (to nothing) every bar on the MRCC display, but all the pads etc are not even set up using USB, so not sure whats going on
help!
update; it works as is should if i use the internal clock on the NDLR, but as soon as i try to "slave" it makes the clock jump around and i would really like to use the pyramid as clock as its quite central in my setup + this also caused the MRCC to freeze up while clock jumping around :|
help!
