Chord range of notes
Is there any way to spread the range of notes without changing the number of notes played? i.e. if I wanted a chord to span several octaves but only have a 4-voice synth.
Try setting the PAD RANGE very wide, and change the SPREAD to 3. It will get you a bit of a wider range.
