3 hours ago
I have a newish MRCC updated to the current firmware. I'm using it to connect some MIDI organ pedals to an MPC One+ for sample triggering.
I have the pedal output connected to the MRCC'S input 1, and the MPC connected to Output 10. I am routing from input 1 to output 10, and the only modifier is Transpose #1.
I have observed that the first 15 notes I press on the pedal always transpose correctly, but the 16th note, and every note thereafter, always reverts to the original note output by the pedal. It doesn't seem to matter which notes I press; I can play the same note or multiple different notes, but Transpose always stops working after 15 notes. I haven't seen this behavior in the midi pedal itself when connected straight to the MPC; it outputs the same note consistently.
