MRCC Request - Note Map - Reverse keys
What Espen did might not give the same results as sending reverse note numbers for keys, but the creativity aspect is the same.
Should reverse the note numbers and have one additional "offset" parameter to shift the most rightside note from which the 1, 2, 3 renumbering of notes would happen.
https://youtu.be/_HPYMJ5eK_k
