If I'm controlling the NDLR via another sequencer which is playing notes to sequence the Chord Degree, when I go into the Pattern Editor these notes mess up the pattern because the Pattern Editor uses NoteOn messages to set the values. I like that idea - but is there a way to disable this?
If you're controlling NDLR with another sequencer then you can't use the Pattern Editor as the NoteOn notes will mess up the pattern. If I stop my sequencer that's controlling the NDLR (so I can go into the Pattern Editor and edit it) I then can't hear what the Pattern will sound like as the sequencer has stopped running.
