Touch Control Near Complete - CC Bugs
#21
(02-04-2020, 08:19 PM)Scotty_123 Wrote: I have posted a rough video showing the main features of the Ndlr Control Templates that I created using TouchOSC...
Thank you for making this. Very impressive! Where are the templates sold?
(02-06-2020, 08:37 PM)Scotty_123 Wrote:
(02-06-2020, 12:21 PM)Scotty_123 Wrote: Bug Reports and Documentation Errata for Firmware beta 1.064 and Manual 1.7
Thanks Steve...  to the best of my knowledge you can't  assign multiple  CCs to a single button press. I will look into this further though to be certain.. Also I got your email that you sent today and responded. I am also posting the bug reporting and documentation errata that I found in my testing to this point. I am actively updating my templates with the new features and CCs that you enabled... I hope that this is helpful.
Motif 2 Midi Port is mapped to CC 24  ... documentation says CC 26
Send Midi Stop Start Continue  on CC 58 has a range of 0 -9 - Documentation says 0 -8
Documentation should indicate as follows:
Value of 1 = All Ports  Value of 2 = No Ports (missing from documentation )  Value of 3,4,5,6,  = USB 1 - 4 , Value of 7 =
MIDI A, Value of 8 - MIDI B,  Value of 9 = MIDI A & B
NEW CC ISSUES
Load Chord Sequence  ... Chord Sequence Load 1 is Broken  AND no option to Load 0 Chord Sequence
Using CC 89 entering value of 1 will not Load Sequence 1 ( Sequence 2, 3 , 4 and 5 do load as expected).
IMPORTANT : There is no way to LOAD  Chord Sequence 0 which is important if you don't want to be in Chord Play mode.
mode...  Solution? perhaps extend CC range  to  1 to 6 and add LOAD 0 as option with CC 89 Value 0 + fix broken Load 1 sequence.
* Previously Unreported Issue (Resolved see Update below)
Updating Motif 2 Pattern length via CC 44 doesn't update the numerical value in yellow on the ndlr hardware when motif
2 screen is selected. The graphical representation updates correctly and the pattern length appears to be selected
correctly and playing properly. It is just the numerical value which doesn't update its value.. Motif 1 Pattern Length value updates as expected.  To be clear
I am referring to the numerical value in yellow that appears on the line where accents are displayed with 0...0.... on the Motif 2 page on the hardware.
CONFIRMED FIXES -  (fantastic!)
All Midi Port and Channel Settings are confirmed to be working
All Menu Corruption appears to be solved when controlling via CCs
I haven't tested the other fixes that are mentioned in the documentation but will confirm later today when I get to that point.  I am actively updating my Templates  with the new features (CCs) that you have enabled etc.  Also I will test your new CC for Toggle All Parts  which you sent via email which I really appreciate. Thanks!
Video Chat?
If you can suggest a time and that works for you via Messenger Video (preferred) or Skype .. I'll organize my thoughts. It shouldn't  take more than 5-  10 minutes to connect at most.  If you can give me your time zone as well .. I am in southern Ontario , Canada on Eastern Standard Time.
Also confirming that the issue "When adjusting clock in values using in values 0  to 7  on CC 68 - the clock in updates perfectly but it also modifies the MOTIF 1 values on menu page 1/3"
This has been resolved with the menu artifact solutions that you implemented... it was part of the same problem that you have addressed in firmware Firmware beta 1.064...  Very happy that you have fixed that issue.  I was thinking that could be tricky one to squash.. Bravo!
* Previously Unreported Issue - Resolved Update
The issue regarding the numerical values for pattern length was just my misunderstanding regarding the interaction between that value and the variation options for the Motifs. I have most of it sorted out and it makes sense. We can scratch that one off the list. There is one related question below if you can confirm or correct my assumption.
  * If you select Variation 6 (Random)  the Numerical values for Pattern Lengths  (1 to 16)  show as 1  for  Pattern 1  AND Zero for Patterns 2 through to 16 . What is the underlying reason for this?
All the other settings pertaining to Motif Pattern Length and the  Variation interactions update the numerical value logically and make perfect sense (now after scratching my noggin for a bit).
Scotty, I got the newer issues logged and have gotten started on them, one thing I noticed is that while I was testing the midi CC for the Start Stop Continue (CC58) I noticed your observed values were off and wanted to let you know, as I assume those are going into the control template.
0 = All Ports
1 = No Ports (missing from documentation )
2,3,4,5  = USB 1 - 4
6 = USB ALL
7= MIDI A
8 - MIDI B
9 = MIDI A & B
I haven't confirmed with Steve yet, but with regards to the Random Variation length indicator, I think what that is saying is that if the length is longer than 1 note it will not repeat in any meaningful way, but if the length becomes 1, then that note will repeat, every 1 note, making the length measurable at 1. Just my guess and I'll let you know if Steve tells me different.
The Load Chord Sequence issue is previously known and in the queue, I'll give you a holler when it's fixed.
Take care, talk soon.
