Pitch-bend pass through?
#11
Hi, I'm having the very same issue.
It seemes to be a bug with the pitch bend signal and it is a really big issue because it makes impossible to use the pitchbend going through the ndlr.
In my setup I have a novation keyboard connected to the NDLR on MIDI IN A and the NDLR connected to a Microfreak via MIDI OUT A. The pitch bend is not properly working, it sends a little bit of bend on the upside but none on the downside. This suggests that the pitchbend message is passing but something happens to it while in the ndlr. If I connect the novation straight to the midi in of the microfreak they work perfectly so it's 100% a ndlr issue.
I'm using channel 1 but using another one doesn't bring any change (Not using the channels 15 and 16 reserved to the ndlr by default).
I'm using fw 1.1.070
Please fix this before anything else.
Bless,
Claudio
Already fixed (V1.1.071)! here is a link to the forum post with the hex file if you would like to update the firmware:
https://conductivelabs.com/forum/showthread.php?tid=235
Champagne!
Thank you Jesse Smile
