Thought on Set Key+ (using external footboard)
Im using a StudioLogic MP-113 to trigger the NDLR. It works fine, but what I've run into is a thought about how Set Key+ functions. So respectfully, if I have this correct, if I choose Set Key+, I am now forced to play two keys on the footboard to sound a note. I need to play the chord degree with one foot and the chord type with the other. It's a handful when your singing and playing guitar at the same time. I think it would be better if in set key+ to allow the NDLR to stay in the chord type that is currently selected when a chord degree is pressed. This at least allows something to sound with only one foot press.
It sounds like you should use Set Key (mode 3) rather than Set Key+ (mode 4). It will play the chord in the current chord type. If you just want to mix it up a bit, you can use Alt-1 or Alt-2 for chord type and NDLR chooses.
(05-13-2019, 01:25 PM)Darryl Wrote: It sounds like you should use Set Key (mode 3) rather than Set Key+ (mode 4). It will play the chord in the current chord type. If you just want to mix it up a bit, you can use Alt-1 or Alt-2 for chord type and NDLR chooses.
Thanks Darryl, can you talk a little more about how this is coded.. "... alt1 or alt2 chord types which will predicatively change the Chord Type". What happening under the hood with alt1 and alt2 ? I never paid them much mind until now.
