Back up all data?
Is there any way to back up all the data produced by the MRCC? To do a Sysex dump or something similar to a PC or Mac, and a Sysex Restore?
I see the data's stored on a MicroSD card, and I assume the "under the left panel" in the manual means "unscrew the panel to get to where the MicroSD card is seated". (Which in my case also means disconnecting a number of things and taking the MRCC off my pedalboard; I have it mounted on a pedalboard where it's talking to several synths, a sequencer, and a few hardware keyboards as part of my live rig). It'd be nice to know I can back up the presets and settings in some easier way besides copying the contents of a card that's hard to access.
Thanks!
No, sorry, no SYSEX, but your data is all stored to the SD card when you make a save and you can access the card under the left end cheek with a hex wrench. Copying the contents to a computer and then replacing them later, or swapping cards will provide a backup system if needed.
