Searching for text in the forums
It seems that you can't search in specific sections of the forums?
This makes it difficult to limit a search for e.g. "Scales" in only the NDLR sections. If you enter "Scales" in the search box, you have to manually wade thruogh all the MRCC posts as well as the NDLR posts.
Or am I missing something?
The search widget is limited to just a general search, however you can sort the results by subforum name too, afterward. There is also a search tab above that banner that has a more fully featured search toolset, although I'll be the first to admit I have no idea how that works. It does appear to support limiting searches to specific areas of the forum.
Thanks - I'll check it out
