Maximum number of routings
Sad
Today I try connect not only portable setup, but also some studio synths.
I used 3 DIN inputs, 2 USB inputs (sequencers and controllers) and 5 DIN/TRS outputs (synths).
I need create routing between all controller and all synths (all to all). Before you ask - yes, it make sense, because sometimes I use two sequencers to control one mono synth, and sometimes I use one sequencer to control few sytnths (in example Keystep Pro). Another example is knobs controller - it's used for all devices in different ways.
When I created 26 routings, it didn't allow me to add any new routing. IS THAT LIMIT FOR MRCC? It's not large setup, there are still 3 empty inputs and 7 outputs...  There was even no any modifier.
I have experienced the same limitation. Couldn't found any information about that in the manual. Would be kind to get an answer here.
Thank you.
