Transmit CC NDLR control messages?
I noticed that the NDLR doesn't send CC's when operated from the front panel. Am I missing something, or does it only receives CC's to be controlled from an external controller? If this is by design, it would be great to if this could be implemented, so we could record a jam in a DAW on a single midi track (say, channel 15, the default for NDLR control), but only the control CC's, not the actual notes being generated. That means we can play the whole thing back and easily edit what we did, instead of record the notes on 4 tracks and edit them individually, which is a tedious task!
Thanks!
Dirk
Well this could be cool, but I could see it causing a ton of issues if someone didn't know it was happening. I'll add this to the feature requests and we can see what the boss says.
Wink
(07-18-2021, 09:25 PM)Jesse Johannesen Wrote: Well this could be cool, but I could see it causing a ton of issues if someone didn't know it was happening. I'll add this to the feature requests and we can see what the boss says.
Well, let's make it an option then..... [Image: wink.png]
cheers
Dirk
