Mod Matrix CC destination not saved?
Proud owner of The NDLR for two weeks, but I noticed something which seems like a bug.
When I use the modulation matrix to send out CC's, the destination is not saved with the Global settings. As soon as I turn on the NDLR or load a Global Setting, the destinations are set to 1-MIDIA even though I changed it and then saved it. Am I missing something? Firmware is 1.1.073
Also in addition, an offset for the MIDI CC value would be nice.
That sounds like a bug. I'll add it to my bug tracker and try to reproduce it.
Thank you!
I also ran across this bug. FW 1.1.073. You're going to fix the bugs in the tracker, don't you!? :-)
Cee
