Ability to change MIDI Thru to MIDI Out
Currently it seems that every pair of in/out is actually a pair of in/merge thru.
Given that we have 6 pairs (2 5pin and 4 USB) is would be great if we could actually have some of the pairs actually be true out and some be true thru.
This device has the possibility of being a part of some pretty elaborate set ups and having to break up the pairs to avoid possible loops can get to the point where the creativity is ruined as we spend time trying to trace down a chain loop that could be easily avoided with a setting that would allow us to just let the out side of the pair to actually be an out instead of a merge/thru hybrid.  This seems to be particularly true with the 5 pin A and B connections and the USB 1 in/out as they are the most often used in my device.
This would be particularly great when using a MIDI controller with many knobs and sliders. Idea
