Reset chord sequencer?
Question
Is there a way to reset the chord sequencer to reliably start at the start of a section? I would find this helpful while editing.
I found you can press Shift Menu to go back to the beginning.
The only way I found to test a section is to make it first, there is no start at position feature (nothing I found).
I'm pretty sure I didn't even know this was possible. Nice one!
(03-14-2024, 01:02 PM)Jesse Johannesen Wrote: I'm pretty sure I didn't even know this was possible. Nice one!
unfortunatly this resets only the Edit position not the "Playhead-Position"
I have found a workaround, which is: All Stop, Disarm then arm chord sequencer, All start. Sometimes you have to reload the chord sequence, so it isn't foolproof.
I have an external start/stop and midi clock device.
I shit menu and the start on the other device. Play ahead position is resetted.
