Remote 7 stopped working
Hello... just powered up my studio and found the devices connected to the Remote 7 weren't triggered via MIDI. Tried another ethernet cable but no luck. Remote 7 is enabled and no change if set to Remote 1-5 or Copy 1-5. With a hardware MIDI tester connected to MIDI Out 1 on the MRCC I am seeing data pass but not if I then move that tester to output 1 of the Remote. FWIW, I'm on 1.1.071 though it was working fine so not sure that matters.
Any thoughts?  Thanks.
