Conductive Labs Support Forum
Permanent routing modifiers - Printable Version
+--- Forum: MRCC Feature Requests (https://conductivelabs.com/forum/forumdisplay.php?fid=25)
+--- Thread: Permanent routing modifiers (/showthread.php?tid=3740)
Permanent routing modifiers - RadekPilich - 06-04-2025
Right now, when you add modifiers to a routing, then disconnect the routing and then re-connect the routing again, it's re-connected with the previously added modifiers.
Great!
However that works only until you turn MRCC off.
I'm asking for the modifiers on the disconnected routings to be remembered, event after after MRCC has been turned off (with saving a preset before turning off obviously).
Maybe add new extras / settings function to clear all modifiers on disconnected routings, but keep them there by default unless cleared by the user.
