Modulation Matrix Problem - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: The NDLR (https://conductivelabs.com/forum/forumdisplay.php?fid=1) +--- Forum: General Support (https://conductivelabs.com/forum/forumdisplay.php?fid=2) +--- Thread: Modulation Matrix Problem (/showthread.php?tid=2411) |
Modulation Matrix Problem - AL1_1956 - 02-19-2025 Hello Everybody I have noticed a problem with the modulation matrix I use LFO1 (with default settings) to modulate Pad Position The Mod amount is 25% The Mod range is 20 to 44 The range of Pad is 1 note It works fine when I push button I : notes are played one at a time But when I push button II , notes from the previous chord are stuck I have checked with MidiOx and it seems that some "Note off" events are missing TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 940038 1 5 147 52 127 4 E 3 Note On 940163 1 5 147 48 127 4 C 3 Note On 940164 1 5 131 52 64 4 E 3 Note Off 940664 1 5 147 43 127 4 G 2 Note On 940664 1 5 131 48 64 4 C 3 Note Off 941039 1 5 147 40 127 4 E 2 Note On 941040 1 5 131 43 64 4 G 2 Note Off 941539 1 5 147 36 127 4 C 2 Note On 941540 1 5 131 40 64 4 E 2 Note Off 942039 1 5 131 36 64 4 C 2 Note Off 942039 1 5 147 40 127 4 E 2 Note On 942539 1 5 131 40 64 4 E 2 Note Off 942539 1 5 147 43 127 4 G 2 Note On 942913 1 5 131 43 64 4 G 2 Note Off 942914 1 5 147 48 127 4 C 3 Note On 943414 1 5 131 48 64 4 C 3 Note Off 943414 1 5 147 52 127 4 E 3 Note On 943789 1 5 131 52 64 4 E 3 Note Off 943790 1 5 147 55 127 4 G 3 Note On => this note never gets a Note Off event 944788 1 5 147 53 127 4 F 3 Note On 945289 1 5 147 50 127 4 D 3 Note On 945289 1 5 131 53 64 4 F 3 Note Off 945789 1 5 147 45 127 4 A 2 Note On 945789 1 5 131 50 64 4 D 3 Note Off 946060 1 5 131 45 64 4 A 2 Note Off Maybe I am doing something wrong Anyway , thanks for reading Have a nice day Alain RE: Modulation Matrix Problem - Jesse Johannesen - 02-19-2025 Thanks for reporting this. I'll see if I can get it to reproduce on my end and make an issue in the bug tracker. RE: Modulation Matrix Problem - House de Kris - 02-20-2025 I tried this out last night per description here. There was a stuck note every time I changed chord degree. I found this odd because I modulate the Pad position a lot. Or, to be emphatic, A LOT. And, rarely, if ever, have stuck notes. The only difference I found was the modulator. In this example, it is LFO1 (mine was set to Uni 5.0s tri) that fails every time. My typical use modulator is MOD2 BiPol 48 beat sine that never, or rarely, gets stuck notes. The modulator, or the rate, may be key in differentiating success or failure. Definitely more experiments are needed, but this appears real to me. |
