Maschine Mikro - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: The NDLR (https://conductivelabs.com/forum/forumdisplay.php?fid=1) +--- Forum: MIDI Connectivity (https://conductivelabs.com/forum/forumdisplay.php?fid=5) +--- Thread: Maschine Mikro (/showthread.php?tid=2403) |
Maschine Mikro - supertemp - 01-30-2025 I have a Maschine Mikro that I wonder if I can use with the MRCC? To put in midi mode you can hold shift + native instruments key which is how I use it on the PC. When I plug into the MRCC it boots up but then is unresponsibe when I press this key combo. It's such a good little controller, has anyone managed to use it with MRCC? Any tips or ideas on how to get it working? RE: Maschine Mikro - Jesse Johannesen - 01-30-2025 No one has reported on the Machine Mikro, but a quick google search tells me that is will probably not be USB Host port compatible as it is not a class compliant USB MIDI device. Are you attempting to connect via USB? |
