Midi Monitor - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: General Support (https://conductivelabs.com/forum/forumdisplay.php?fid=14) +--- Thread: Midi Monitor (/showthread.php?tid=2034) |
Midi Monitor - Pasquada - 10-14-2022 Hi ?? all! I’m excited to be using my new MRCC with my Elektron gear … but second day in … the monitor isn’t showing any data occurring or shown … Wasn’t like this when I first got it in day one. There was data happening But now the LOAD/SAVE is on Factory … where as when I first turn on and connected it showed red user I think ? Any ideas ? thanks. RE: Midi Monitor - Jesse Johannesen - 10-14-2022 Hey, can you tell me how you're connecting things in your setup? Elektron gear is all listed as not working for USB midi on the MRCC so if you are not using DIN ports then that is the likely cause of the issue. If you are using DIN ports and still having issues let me know and I'll try and get you sorted out. RE: Midi Monitor - Pasquada - 10-14-2022 (10-14-2022, 04:33 PM)Jesse Johannesen Wrote: Hey, can you tell me how you're connecting things in your setup? Elektron gear is all listed as not working for USB midi on the MRCC so if you are not using DIN ports then that is the likely cause of the issue. If you are using DIN ports and still having issues let me know and I'll try and get you sorted out. Hi Jesse My apologies. I have Digitakt and Digitone each with their own Analog Heat MkII - and using an Arturia KeyStep for the Digitone. As well as a 1010Music BlackBox with Novation Launch Control XL. Each a Radial ProD2 Stereo DI Box. All this going into the Yamaha MG20XU mixer. Then out to two Stereo Roland KC-990’s. Eventually am looking to trade my Singular Sounds Aeros Studio Looper for a Musicom EFX LE-II foot controller … so I can play along to program changes and song mode. (10-14-2022, 04:33 PM)Jesse Johannesen Wrote: Hey, can you tell me how you're connecting things in your setup? Elektron gear is all listed as not working for USB midi on the MRCC so if you are not using DIN ports then that is the likely cause of the issue. If you are using DIN ports and still having issues let me know and I'll try and get you sorted out. I’m not using USB - only 5 Pin DIN … RE: Midi Monitor - Pharaoh Magnetic - 10-19-2022 I'm having this issue as well. Elektron gear all connected with DIN midi. Monitor was working beautifully at first, now no activity whatsoever. Everything else seems to be working fine. RE: Midi Monitor - Jesse Johannesen - 12-03-2022 The MIDI Monitor starts out paused, you need to press the enter button to begin to monitor it's data. (you'll need to navigate to the Pause symbol first) Are we talking about the MIDI Monitor in the Tools section or the Activity page? |
