Behringer RD-6 Midi sync issue - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: MRCC - MIDI Router Control Center (https://conductivelabs.com/forum/forumdisplay.php?fid=13) +--- Forum: Hardware MIDI Connectivity (https://conductivelabs.com/forum/forumdisplay.php?fid=22) +--- Thread: Behringer RD-6 Midi sync issue (/showthread.php?tid=1920) |
Behringer RD-6 Midi sync issue - blberman - 03-13-2022 Hi, I am having trouble getting the RD-6 to sync using Midi DIN cable. I have the following setup: - Midi clock coming in on midi DIN port 1 - port 1 routed out to ports 1-4 - out port 1 routed to CV-OCD to modular (no filters): OK - out port 2 routed to TR-8S: (output filters enabled so only clock and start/stop are sent): OK - out port 3 routed to Cyclone Analogic TT-303: (output filters enabled so only clock and start/stop are sent): OK - out port 4 routed to Behringer RD-6: (output filters enabled so only clock and start/stop are sent): DRIFTS AFTER 3-4 BARS I've also tried disabling the output filters, and I've tried other out ports and I get the same behavior. One other thing to note, the MRCC freezes when I attempt to connect the RD-6 via USB to the MRCC midi in/out port A. I verified the RD-6 syncs just fine when I connect it to the thru port on any of the other devices synced to the MRCC listed in the configuration above. MRCC firmware version: 1.1.035 thanks, Ben Berman |
