Pause chord change on single part? - Printable Version +- Conductive Labs Support Forum (https://conductivelabs.com/forum) +-- Forum: The NDLR (https://conductivelabs.com/forum/forumdisplay.php?fid=1) +--- Forum: General Support (https://conductivelabs.com/forum/forumdisplay.php?fid=2) +--- Thread: Pause chord change on single part? (/showthread.php?tid=1267) |
Pause chord change on single part? - Durwin - 01-02-2021 Hi there, Just wondering if it's possible to have one part (drone or otherwise) stay on a particular chord while the other 3 parts shift? ie the drone part stays on the I chord, and the pad and motif parts shift as I either sequence or press other chords? Cheers RE: Pause chord change on single part? - Jesse Johannesen - 01-03-2021 (01-02-2021, 08:44 PM)Durwin Wrote: Hi there, Yes, the the drone part can do this. In fact any of the drone trigger patterns that are not preceded by 5 circles will play on the I Chord Degree. The circles indicate that it will play in whatever Chord Degree is selected. Jesse RE: Pause chord change on single part? - Durwin - 01-03-2021 Ok great - can other parts do this too? So Drone, Pad and motif 1 don't shift while motif 2 does? RE: Pause chord change on single part? - House de Kris - 01-04-2021 Motif patterns can be set to Chord, Scale, or Chromatic. ONLY Chord mode responds to the Degree buttons pressed. Check page 48 of the manual. |
